2010 PTO Problem Help a dummy
rex
01-30-2004 10:51:20
I bought the 2010 gas tractor s/n above 60000 everything works runs fine, lights(even small dash light works) however the PTO shaft will not engage,when I move the lever back and forth it feels like something has come unhooked?
Mike M
01-30-2004 11:28:31
 Re: 2010 PTO Problem Help a dummy in reply to rex, 01-30-2004 10:51:20
Did it work before ? Someone may have tried to engage the pto without the tractor running,per warning decal that should be on tractor and may not be,It could be a roll pin on the engagement lever unfortunatly these are on the inside of the housing.I fixed one once
and borrowed an I&T repair manual and glad I did
as there are some hidden bolts that hold the rockshaft housing on and I would have not found them without this book.If you find out that this is the problem I would try to find a spiral wound roll pin for replacement these are a little stronger.
