2555 PTO Lack Of Power
Gerard
07-06-2004 21:46:38
Had problems recently with trans pump lines - after replacing cracked line, hydraulics worked fine except for the pto which is not putting out enough power to run our shredder. Trans pressure are within specs - How can I check pto pressures and could the problem be in the trans cover area ?
Lucas
07-07-2004 19:12:15
 Re: 2555 PTO Lack Of Power in reply to Gerard, 07-06-2004 21:46:38
Hi Yes there could be a problem in the shift cover. The PTO clutch pessure can be check right at the shift cover I'm not sure wich port it is but the presure should be about 150psi. I have seen alot of these 55 series burn out clutch packs most happen right around 5000hrs. If it is your clutch pack you may want to check the other clutches when you fix that one(high/low, MFWD, etc.) well hope this helps good luck
Lucas
