AMPMETER CLARIFICATION
Ken
07-06-2004 21:39:28
I see the ampmeter as having a plus side & a minus side. What side is the "load" side, & what side is the "hot,battery supply"side?
Thanks, Ken
Bob
07-06-2004 23:13:07
 Re: AMPMETER CLARIFICATION in reply to Ken, 07-06-2004 21:39:28
It depends on the ammeter, and whether it is used in a positive ground system, or a negative ground system.
One side will be connected ONLY TO THE BATTERY.
The other side will be connected TO THE CHARGING SYSTEM AND ALL ELECTRICAL LOADS.
After verifying the above, if it reads backwards, swap ALL wires to the opposite posts.
Ken
07-07-2004 20:24:36
 Re: Re: AMPMETER CLARIFICATION in reply to Bob, 07-06-2004 23:13:07
Thanks Bob,
I finally have enough information that your responce makes sense. I'm 99% sure that I have it wired correctly, & still the amp shows no charging, even after grounding the Field on the generator. I think I will have the generator checked again. The amp does show discharge when the lights are turned on. (this is on a J.D. LA)
Ken
Bob
07-07-2004 23:08:09
 Re: Re: Re: AMPMETER CLARIFICATION in reply to Ken, 07-07-2004 20:24:36
Check the VOLTAGE at the battery, and also at the "A" (Armature) post on the generator.
Without a functioning charging system, a 6 Volt battery will quickly drop to about 6.25 Volts (after being charged with a battery charger to nearly 7.5 Volts).
For your generator to fully charge the battery, it must be putting out AT MINIMUM, 6.9 Volts,and probably closer to 7.5 Volts. Your ammeter will not swing to positive charge unless the generator is putting out enough voltage so that current is flowing INTO the battery
