520 Power steering problem
Lucas
07-06-2004 18:57:38
I have a 520 with power steering it will steer perfect one finger to turn it when you start it an it is cold. When the oil gets hot it will bind to the left sometimes. The steering valve gets very hot. I check the presure and when the steering wheel is still the pressure is 600-700psi. When check the relief it goes to 1100psi. I changed the flow control like it says to in the book, down to 130psi, and I have no power steering. I did the cylinder leak test and it is not leaking I just get a small drisal. So does anybody know where to turn next. Thankyou for any help
Lucas
ChuckW
07-07-2004 11:34:30
 Re: 520 Power steering problem in reply to Lucas, 07-06-2004 18:57:38
Lucas, I've been into many of these units. Most of the time I removed the pedistal and checked the vanes and replaced the rectangular gaskets. Also you check for any broken pins. When I removed the gear I rotated it 180degrees so it would be using unworn material. Then I checked the valve mechanism and see if the screw has bad wear and have at time filed it to make the screw surfaces uniform, takes a little time. Beyond that the dissambly can show wear places on the cam and I've tried to get another part if this is the case. Also you need proper clearance at the worm/gear. Since everything is worn it is a balance in getting middle ground on wear. Good luck....
Tyler-MO
07-07-2004 07:24:53
Lucas,
Does your cam stick when you turn it to the left or is the bind in the pedistle?? I had similar trouble after reassembly and it turned out that the tolerance was too close fromt the worm gear to the sector gear. The book didn't compensate for 40 + years of wear on that worm gear for correct back lash.
Also you might try disassembling the steering valve and inspect it for nicks or burrs...this could cause it to stick and make the oil hot because it builds pressure and causes the relief valve to open constantly..
Keep in mind I'm no expert...Clooney would probably be the best here on the finer details....I just suggested some things that I had to find out for myself the hard way.
In all reality...when you've rebuilt a few of these they are fairly simple.
Good Luck
Tyler in Missouri
