48 A oil leak(clutch wheel)
Jack
07-06-2004 15:09:56
Got a 48 A that runs good but is leaking the crap out of oil from the clutch wheel.How do I fix it,main bearing maybe?Its bad enough to do something about.Thanks.
ho
07-07-2004 15:31:27
 Re: 48 A oil leak(clutch wheel) in reply to Jack, 07-06-2004 15:09:56
their is a drain hole that needs cleanig under the belt wheel if it is runig down the casting .My 48 A did the same thing you will need to take clutch fork out then the belt wheel to get that tin off there is a drain hole in the botom of that. That drains back to the block it needs cleaning if that does not help you have other problems like a seal or somthing. i cant remeamber but you might have to take the the clutch driver as well as clutch plates out If so make shore the index marks on the clutch driver and the crank are lined up like this >< it may be a vee and a star If you dont it will be out of ballence and shake like NO TOMOROW.Hope this helps I do not get iternet time like I like to but will check back to see how it is going .Howard
Jack
07-08-2004 11:22:19
 Re: Re: 48 A oil leak(clutch wheel) in reply to ho, 07-07-2004 15:31:27
Thanks Howard,for a minit there I was thinking no one liked me enough to reply,ha ha.It acts like a drain hole by how much is coming out.Jack
