Clooney , John T, others with D experience
JC
07-06-2004 15:08:37
Engine idles smoothly down to about 350 RPM.
As I open the throttle with no load on the engine, it runs smoothly to about 680 RPM, then it starts to "hunt" very badly. If I add a small load - by driving the tractor in high gear, the engine runs very rough and the governor swings the throttle shaft from full open to fully closed and back to fully open.
If I over-ride the governor and hold the throttle lever at a fixed position, the engine runs smoothly but the RPM drifts up and down.
What's been done:
Engine rebuilt.
Carb overhauled.
Carb passages re-checked for blockages.
Governor overhauled.
NOTE: The linkage from the governor to the carb may not have be re-assembled to it's original factory-set length.
Suggestions..... ....
{I posted this over the July 4th weekend. Would like more ideas}
Thanks,
JC
Bob-Wyo
07-07-2004 19:16:06
 Re: Clooney , John T, others with D experience in reply to JC, 07-06-2004 15:08:37
JC, I really feel you have a fuel starvation problem. I hope Clooney don't mind as I have done a copy/paste one of his, as he explains things way better than I can. If none of this helps you can do a CARB PROBLEM SEARCH. This was on a G with about same problem as your's.
The first thing to do is try that fuel flow test again & give it a good 30 seconds.. If you can�t make it 30 seconds without the fuel flow stopping you have found your problem..
~Your problem sure does sound fuel related though with that choke position having such a big effect.
~The first thing that comes to mind on your G is that the main nozzle might be in upside down.. Depending on your carb, a lot of those G�s had the main nozzle with angled bottom on them. In a lot of cases those main nozzles are reinstalled with the angle facing up, that is incorrect & the angled end goes towards the bottom.. In fact there are a few old posts on this board stating that angle faces up & that is incorrect.
~If you have the angled main nozzle & it is upside down DON�T RUN A TAP INTO IT TO REMOVE IT.. Even when installed correctly those angled nozzles must be carefully removed.
~If you don�t have the angled main nozzle or it�s installed correctly then the one you have should come out for cleaning to be sure all the side air emulsion holes are clean & not plugged with small dirt particles.. Just run a tap into the bottom of the main nozzle about �� then insert a piece of all-thread rod with a stack of washers & a nut on the all-thread,, when the nut is tightened the nozzle should pull out.. If your carb was overhauled a year ago that nozzle should come out easily.. On the angled nozzle just insert a machine screw in the tapped bottom of the nozzle, then clamp a pair of vise grips on the screw & tap down on the vise grips with a hammer..
~Again depending on your carb there could be a small transfer fuel hole in the side of the main well that could be plugged with rust [you must look closely to even see it if it�s rusted shut.. If that hole is plugged it could cause a problem like you have..
I have my doubts you have a vacuum leak as that effects the idle & not open throttle conditions.. Once the throttle plate is opened far enough the air flow is so great a vacuum leak won�t have any effect at all..,,
~The float setting could have an effect but that would probably also effect the idle & starting..
I guess here�s my take on your problem from what you have said.. If it keeps slowing down & stalls even with the choke on that kind of points to it running out of fuel in the carb.. SO do a 30 second fuel flow test.. If it passes the fuel flow test suspect the main nozzle or a plugged main well fuel feed hole.. There is also the possibility you have a plugged float bowl vent as that can cause a metering problem under load.. Now from Bob Take a #40 drill (6")or a rod that size an after removing the load screw see if it will go all the way down through the orfice, I just found a overhauled carb that was 1/2 plugged. Unhook throttle linkage from carb,Put throttle lever to wide open, then hold carb wide open, linkage should be 1/2 hole short of hole, or even 1 full hole won't hurt, just makes better gov response on some.
When holding carb throttle in a even rpm did you try opening/closing load screw?, trying a little choke? and did it change run condition? As Clooney said, the 30 sec flow test will determine if its a fuel flow or carb problem. Is float rubing/sticking on side of bowl? have found float arm and pin to be so worn it would allow this. Is float set for 3/8 to 3/4" FUEL LEVEL, D'S are 3/4" but have 2 set at 3/8" no difference noticed.
JC hope this helps, if not post back,(will be watching for it), in the mean time will sift through the cobwebs and see if anything more pops out.
Just can't have a D running like that.
Bob
JC
07-09-2004 06:10:02
 Re: Re: Clooney , John T, others with D experience in reply to Bob-Wyo, 07-07-2004 19:16:06
Bob,
I tried a number of things today and I made the problem worse!@#$%^&*(!@#$%^&*$%^&!
Fuel Flow - I ran a full gallon of gas thru the carb. Great flow - 1/8" to 3/16" diameter stream continuous for 3 to five minutes - so no fuel flow problem.
Throttle Linkage - I adjusted the governor-to-carb linkage. It was way too long.
Ran the Tractor - It runs quite well at slow idle and with the throttle slightly open. As soon as you add a load or raise the idle speed to about 600 RPM, the governor hunts madly and the engine revs up and slows down. A buddy of mine checked the governor spring on another "D" and found the spring to be much softer so I've ordered a replacement spring.
Float Bowel Level - Then I raised the flow level thinking that the load circuit may not be picking up enough fuel. The slow idle is now much worse and the engine still hunts wildly on the governor.
Manual Override of the Governor - When I accelerate the engine by rotating the throttle lever on the carb, the engine speeds up, runs fairly smoothly, and doesn't hunt wildly. The RPM varies slowly because there is no governor action. There seems to be a dead spot as I slowly speed up the engine. This may be an important clue - ie. the carb isn't delivering the correct mixture in the mid range and the governor is hunting thru this zone to try to control the engine.
Valve Timing - is within the I&T manual spec of + or - 1" of the horizontal timing mark on the PTO cover. I am about 3/4 ahead. When I timed it during engine overhaul, the next tooth put me about 1" late.
The following are my comments in capital letters to your suggestions:
I WILL SEARCH CARB PROBLEMS
GOT A FEW MINUTES OF CONTINUOUS FLOW, 1/8 TO 3/16" STREAM.
THE CHOKE MAKES IT WORSE
MY "D" HAS A FLAT TOPPED NOZZLE, AND IT CAN'T GO IN INVERTED.
PROBED ALL OF THE LOAD CIRCUIT PASSAGES AGAIN, THEY ALL APPEAR TO BE OPEN.
SINCE IT RAN WELL AT LOW RPM BEFORE I RAISED THE FUEL LEVEL, I ASSUME THAT THERE ARE NO VACUUM LEAKS.
RAISED IT TO ABOUT 1/4" BELOW THE RIM AND THE IDLE PERFORMANCE GOT MUCH WORSE.
I guess here�s my take on your problem from what you have said.. If it keeps slowing down & stalls even with the choke on that kind of points to it running out of fuel in the carb.. SO do a 30 second fuel flow test.. If it passes the fuel flow test suspect the main nozzle or a plugged main well fuel feed hole.. There is also the possibility you have a plugged float bowl vent as that can cause a metering problem under load.. I CAREFULLY RE-CHECKED ALL OF THE PASSAGES, MAKING SURE THAT THEY WERE OPEN AND WOULD PASS LOTS OF COMPRESSED AIR.
I USED A SOFT WIRE WHICH WENT ALL OF THE WAY DOWN. I ALSO HAD ALL OF THE PLUGS OUT AND MADE SURE THAT ALL OF THE DRILLED PASSAGES WERE OPEN AND WENT TO THE NEXT PLACE OR OPENING.
MINE WAS AWAY OFF - IT WAS PAST THE HOLE INSTEAD OF BEING SHORT OF THE HOLE. I ADJUSTED IT PER YOUR INSTRUCTIONS.
I NEED TO DO THIS AGAIN, AND CAREFULLY NOTE THE RESULTS!
DONE - ITS GOOD
FLOAT MOVES FREELY AND DOES NOT CONTACT THE SIDES OF THE BOWEL.
3/4" WORKED GREAT ON IDLE BUT I HAD THE HIGH SPEED PROBLEM. I TRIED 1/4" - NOW IDLE AND HIGH SPEED ARE BAD.
I'M PROBABLY MISSING THE OBVIOUS. I WONDER IF I'VE GOT SOMETHING ASSEMBLED WRONG IN THE GOVERNOR. HATE TO TAKE ALL OF THAT OFF AGAIN.
REALLY APPRECIATE YOUR HELP.
JC
Bob-Wyo
07-07-2004 13:01:40
JC had a long list of things to check and they dropped us off here. If no one gets to you, will resend tonight from home as I got to run now.
Bob
JC
07-07-2004 13:07:31
 Re: Re: Clooney , John T, others with D experience in reply to Bob-Wyo, 07-07-2004 13:01:40
Bob-Wyo,
Please send tonight. I'm going there tomorrow -early morning.
Thanks,
JC
ET
07-07-2004 07:10:56
I'm not a D person either, but it sure sounds like you are running out of fuel at the higher rpm's. If you open the drain on the carb. bowel and let it run for a while does the flow remain constant?
JC
07-07-2004 09:22:38
 Re: Re: Clooney , John T, others with D experience in reply to ET, 07-07-2004 07:10:56
Hi ET,
Thanks for the suggestion. I will try an extended fuel flow test to make sure that volume is available to the bowel. Also, I didn't CAREFULLY note the length of the rod from the governor to the throttle lever when I dis-assembled it for claening and painting. The I&T manual has a procedure for adjusting it. I will try that as well.
regards,
JC
JC
07-07-2004 02:53:39
Hi John,
Thanks for responding. I re-posted because I put this request up during the holiday weekend and only got one response. I noticed that the number of responses to other posts were low as well so I thought I'd ask again.
I've used your advice on electrical problems to help a few friends on their tractors - much appreciated.
I prefer electrical problems to mechanical problems. But alas, my first restoration is an unstyled "D". The only electrical on it is a mag, two plugs, two plug wires, and a shut-down switch I've wired from the mag to the steering shaft support.
Thanks again!
Blessings,
JC
John T
07-06-2004 20:01:50
JC, I saw this post earlier, Im NOT ignoring you, Im just not much of a D man generally speaking and dont have the answer youre lookin for. Im an Electrical Engineer and give seminars at national JD shows and write some for Green Magazine, but thats on electrical topics instead of governors n hydraulic n clutches n stuff like that.
Good Luck n God Bless ya, Im sure others can help you out.
John T
