JD 4020D Oil in Coolant
Phil
07-06-2004 13:33:16
A few days ago I posted a message about having hydraulic fluid in my coolant and everyone said it is impossible because they are separate systems and it must be engine oil. How or where would I be getting engine oil in the coolant and where should I look. When I look at the oil it is clean, there isn�t any water in it and the same for the hydraulic fluid. I just thought it was hyd fluid because it went low but I think there is also a leak. I guess the bottom line question is where would oil get in the water. Hopefully it is outside the engine. It is a 1965 JD 4020 Diesel with PS trans.
Thanks, Phil
JDknut
07-07-2004 10:35:32
 Re: JD 4020D Oil in Coolant in reply to Phil, 07-06-2004 13:33:16
I had it the other way around, antifreeze in the oil in my Mannheim Deere, ended up doing an inframe, it was pitted liners. G-man has it right, he knows his stuff.
G-MAN
07-06-2004 13:40:17
To get oil in the water, it has to be in a location where the oil pressure is higher than the cooling system pressure, which pretty much eliminates leaking liner o-rings. The most common area would be the engine oil cooler, although it's possible (although not terribly likely) for a head gasket to leak engine oil into the cooling system if there is a split between the passage that feeds oil to the top end of the engine and an adjacent coolant passage. Also possible is a blown head gasket leaking compression and some oil/fuel into the cooling system. How much oil are you getting? I'm betting on the engine oil cooler.
Phil
07-06-2004 17:37:39
 Re: Re: JD 4020D Oil in Coolant in reply to G-MAN, 07-06-2004 13:40:17
Thanks, I'll take a look at the engine oil cooler. I don't think there is a lot of oil getting in but it just started to happen so I'm not 100% sure how much. I have about 30 acres of straw to bale before I can look at it, do you think its a problem to run like that for a day or so.
JDknut
07-07-2004 10:41:22
 Re: Re: Re: JD 4020D Oil in Coolant in reply to Phil, 07-06-2004 17:37:39
I'd check the oil real real close to make absolutely sure antifreeze ain't gettin' there. With my pitted sleeves, I had microscopic amounts of oil in the antifreeze, not enough to make a slick but enough to color it a really funky dark green. Let it sit for a while (at least overnite, the longer the better) and then drop a little oil out of the base into a flat pan, if there is antifreeze you will see it. Also change the oil filter and cut it open and look at the inside, you'll see it there, too. If so, the less you run it the better. I caught mine in time, saved the crank and cam. Good luck on that, hope it is the oil cooler as the consensus says.
