4010 hyd
JJ
07-06-2004 05:31:59
I got the 4010 out over the weekend to do some mowing. I checked the fluid levels before I started and they were good. The 3 point was down before I started the tractor. As I started it the 3. came up and it shook and chattered all the way. After I mowed for about 15 minutes the power steering no longer worked. I tried the brakes and both pedals went all the way down and pulsated.
Does this sound like the hyd pump is bad or is there a valve or something else that could be causing the problem?
Thanks in advance for any info you can provide.
gwece
07-06-2004 11:15:05
 Re: 4010 hyd in reply to JJ, 07-06-2004 05:31:59
JJ: Make sure the coupler from the crankshaft to hydraulic pump has not failed and the hyd pump shaft is just turning free in the coupler. This happened to me on my 4010 once.
gwece
Rodney A. Johnson
07-06-2004 10:18:13
The only time I have encountered the situation you described, was when a hose broke on a remote cylinder and a lot of fluid was lost.
Your stroke valve in the hyd. pump could have stuck so that it would not pump, or your transmission pump could have failed, thus not supply the hyd. pump with oil.
The stroke control valve probably can be removed and "rebuilt" without removing the hyd pump. If the transmission pump failed, I think you might have to split the tractor...not sure if you can replace that pump from the top after taking the transmission cover off.
There is a valve under the dash that is suppose to close if the pressure drops below 1900 PSI. But you still should have steering and brakes. Sounds like a total pressure loss.
