Bush Hog size for a 820
Tye
01-30-2004 08:41:01
What size bush hog would be a best fit for a 820 or 830? I know a lot of it has to do with the thickness of grass being cut, but what size do most people pair with that size tractor? Thank you very much.
3 cylinder or 2 ?
01-30-2004 14:41:21
 Re: Bush Hog size for a 820 in reply to Tye, 01-30-2004 08:41:01
Big difference.
Tye
01-30-2004 16:14:35
 Re: Re: Bush Hog size for a 820 in reply to 3 cylinder or 2 ?, 01-30-2004 14:41:21
Two cylinder
Joe P.
01-30-2004 10:43:03
Depends on how fast you want to go.
ON THE OTHER HAND -- anyone looking for much more than a 7 footer, is looking for the wrong implement. If you have that much to mow, you should be looking for a sickle bar hay mower - and put that area to use.
John T
01-30-2004 08:54:07
Tye, Ive only used one or two 820's, but with any decent 820 or 830, you ought to be able to pull AT LEAST an 8 up to a 10 ft or even larger rotary mower, as you say DEPENDING on the grass or brush or what it is youre mowing. I always want AT LEAST a mower wide enough to cover the rear wheel tracks, which depends on where your wheels are set. I cant imagine an 820 with less than a 7 or 8 foot mower, it just wouldnt look right lol and perhaps even a bat wing fold up 10 or 12 footer if sharp and in decent grass/brush not wet conditions. That heavy wet laid over clumped fescue can sure make one grunt though and the blades better be sharp plus the PTO, U Joints, any slip clutches and drive train all in top shape.
Good Luck, God Bless
John T
