4010 weak hydraulics
gwece
07-05-2004 19:43:29
My 4010 has very slow rockshaft and remote cylinder hydraulics (steering & brakes are fine). I just replaced the transmission pump which stopped the squealing, but hydraulics are still slow. Have also checked the transmission screen and it is ok. The troubleshooting section of my JD manual points to checking the pressure control valve for foreign material. I took the front part of that off and all I could get out easy was one valve and one spring. Looks like there is another shaft in there and according to the parts drawing there should be more parts as well. The pressure control valve appears to be of the 4020 variety from the online JD parts source catalog, but the one I have does not look exactly like any of the ones for the 4010 or the 4020's. Any body have any advice on getting this thing apart, or should I be looking elsewhere?? Thanks!
G-MAN
07-06-2004 13:50:56
 Re: 4010 weak hydraulics in reply to gwece, 07-05-2004 19:43:29
Did you happen to check standby pressure or the pressure out the back of the remote first? I just went out on a 4020 with slow/weak hydraulics thinking that it could possibly be a pressure control valve problem. I found the hydraulic pressure to be 800 psi low. I adjusted the screw on the stroke control valve to get the pressure back up to spec and solved the problem. If you got the main spool out and it's moving freely, that probably isn't your problem.
gwece
07-06-2004 20:11:56
 Re: Re: 4010 weak hydraulics in reply to G-MAN, 07-06-2004 13:50:56
G-Man:
No, I didn't run a pressure test out the back of the remote first (didn't have a guage setup). I took my pressure control valve to the local JD dealer today. A mechanic had to take a punch and drive the shaft that was in the rear of the pump out from the back bleed screw. If it was supposed to move on it's own it wasn't doing so. I also noticed when I took the control valve out initally, there was a piece of metal shaving in the front of the valve (where the oil comes in from the main hyd pump). Could that have had the orifice partially blocked? I had the local JD dealer order me a new pressure control valve. If that don't do it, I'll run the standby pressure check. What do I need to do the check with? Just a 3000 psi gauge and necessary adapters to the rear port?? Thanks for responding. You guys are great help here!!
gwece
G-MAN
07-08-2004 11:06:18
 Re: Re: Re: 4010 weak hydraulics in reply to gwece, 07-06-2004 20:11:56
I've never had one of those valves apart, but looking at the parts picture (I assume you have an early 4020 if he was able to get behind the spool to drive it out), if that back spool were stuck, that was probably the problem. And if you found chunks in there, that's also a good indicator of where the problem is. And yes, you can just rig up a 3000-psi gauge with a JD coupler tip to check pressure out the back. It will be slightly lower than actual standby pressure - measuring that requires tapping into the actual PCV itself - but will be close enough. It's common for those systems to lose pressure over time due to weakened stroke-control valve springs and the like.
