Frozen 3pt
Russ C.
01-30-2004 08:36:38
The lever/conecting rod on my 3-pt keeps freezing. I have slid the dust cap up and tried to spray some wd-40 down the tube with no luck. Is it easy to remove, dry and lubricate for someone who isn't mechanical?
Rusty Scupper
12-29-2005 11:47:34
 Re: Frozen 3pt in reply to Russ C., 01-30-2004 08:36:38
It has been a long time since my original post, and I haven"t looked into it further.
How hard is it to remove the rockshaft cover? Also, is it easy to remove it at both ends.
Thanks, not very mechanical.
Mark
01-30-2004 15:52:56
That cable runs underneath of the platform. It will need to be removed to replace it.And also the right rockshaft cover needs to be removed.
Mark
01-30-2004 10:01:15
You will need to replace that cable.
old
01-30-2004 09:44:36
That is hard to answer since you didn't tell us what the tractor is etc
Russ C.
01-30-2004 10:43:09
 Re: Re: Frozen 3pt in reply to old, 01-30-2004 09:44:36
It is a JD2510 - should have included that info.
