JD 60 Question
Don
07-05-2004 13:50:36
I recently fully restored a JD 60 gas, serial no. 6004055. I just starting having a problem where after starting and running great at first, it will sputter and stop running after a little while unless I pull the choke out about half-way. It usually doesn't want to run decent after that unless the choke is pulled out, and even then sometimes it sputters a little. The carb was professionally rebuilt and it has new pistons and rings, ignition parts, timing and points set correctly, etc. It ran and started great until just recently, but it hasn't been that many hours since the restoration. Someone told me I should try hotter plugs. I would appreciate any thoughts anyone could give me. Thanks in advance.
Mike M
07-06-2004 13:13:30
 Re: JD 60 Question in reply to Don, 07-05-2004 13:50:36
Haveing to pull out the choke usually indicates a fuel flow problem,plugged carb.passages or if you have an automatic fuel shut off bowl it is plugged up inside or the little rubber washer isn't dropping down when the oil pressure pushes the plunger down sometimes they stick to the top of the housing.But I once had a bad condenser act like this also,swap one out of another tractor or put back in your old one.
JD Van
07-05-2004 19:19:53
I am going to venture a guess but probably w/o adequate data to back it up. Why it starts good and then later rquires choking is puzzling to me but usually your symptoms indicate that one of the passages in the carburetor is partially or fully plugged. I assume this is a duplex carburetor and not an early single barrell "All Fuel" carburetor so testing which cylinder is being starved for gas might be in order. This can be done by disconnecting each spark plug wire, individually while running, to find out which cylinder is not firing.
Another thought is that it might be heat related and that the intake manifold gasket to the head or the carburetor is leaking when the engine warms up. Have you re-torqued all the manifold and carburetor bolts?
Checking for a leaking gasket is quite easy using a spray that is flammable at the gasket interfaces to see if things change.
Try these suggestions and get back to us with your results.
Paul
07-05-2004 19:09:58
I don't know that I have a answer for you, only to say I have an almost identical issue with a 2510 my son restored. Ran it in a parade, cut three fields of hay and then it sputtered to a stop. Symtoms now are identical to yours. We took the fuel pump apart thinking dirt from the fuel tank got in the pump. The screen in the pump had trapped a lot of dirt. After cleaning the symtoms persist. There is fuel up to the carbarator. I backed out the ajustment jet on the shutoff solenoid with an improvment, now it idles with the choke all the way out but will not run under load. Next I am going to go through the carbarator. I am interested to see what advice you get. Good luck. By the way, my son also has a 1953 60 he continues to upgrade. This weekend it got a new generator and regulator with great results.
