Flywheel cover
Lary
01-30-2004 08:28:32
Is a late JD A flywheel cover the same as found on a JD 60? thanks ,Lary
Mike
01-30-2004 17:20:02
 Re: Flywheel cover in reply to Lary, 01-30-2004 08:28:32
They will interchange the only difference is the A has hole for the starter rod and the 60 has a timing window but will work on either
Clooney
01-30-2004 13:44:02
Larry, no,,,,, well to answer your question the part numbers are different anyhow..
~I haven't ever tried to swap those covers but the "60" uses an ignition timing hole & "A" doesn't so that MIGHT be the only difference..
[email protected]
Lary
01-30-2004 14:57:41
 Re: Re: Flywheel cover in reply to Clooney , 01-30-2004 13:44:02
Mr. C thanks for the quick response. Lary
