Combine
Ryan
07-05-2004 11:28:29
I'm thinking about replacing my old 6600 combine. I'm looking at a 9400 4WD, but I've heard that they don't have very much power. I know they are a small combine, will it handle a 6 row corn head? Thanks for any advice.
Mark
07-05-2004 20:20:15
 Re: Combine in reply to Ryan, 07-05-2004 11:28:29
I went from a 6620 to a 9500 on 600 ac. in central Il and no regrets. Do not buy a 9400. I am good friends with local Deere dealer mechanics and a quiet secret is broken crankshafts on some 9400 engines due to different design and dead weight of pulleys on crank end not used on 95 and 9600 engines. Here 9500 is cheaper same hours as few 9400's were sold.
Randy V (SD)
07-05-2004 12:15:55
Ryan,
the 9400 will handle a 6 row head as well as your 6600 but you dont want any more. the 9400 and 9500 are basically the same machine except the engine and the straw walkers are shorter on the 9400. You are right about the power problem though. believe it or not, the 9400 only has a 359 cube engine and your 6600 has the 404. I've heard that the 9410's had more power though. If I were you, I would go for the 9500. They have the 466 turbo engine and more cleaning area and a larger grain tank. If you aren't looking to spend that much, I have a late model 6620 with 2100 hours that I am considering selling. Good Luck!
Aaron Jacob
12-17-2005 06:04:38
 Re: Re: Combine in reply to Randy V (SD), 07-05-2004 12:15:55
I am looking to purchase a combine, how much are you asking for the 6620? I need something that is fld ready.
Mike Aylward
07-05-2004 13:31:59
Ryan, Randy is right in the basic differences between the 9400 and 9500 combines. There were three different horsepower levels in the different years of 9500's (same 466 cubic inches or 7.6 l)and two engine sizes in the 9400's- the early 359 and the later 414 or commonly known as the 6.8 l engine. There won't be a lot of difference in price between the 9400 and 9500 for the difference in capacity. I own a 9500 and it is an excellent machine. Most folks that have 9400's around this area (northeast Missouri) use 6-row corn heads and 20' platforms on them. I use these same sizes on my 9500 and it plays with both. You should have no problems with these sizes on a 9400. Hope this helps. Mike
Ryan
07-05-2004 13:02:27
Randy,
Thanks for the info. I might look around for a 9500 or a 9410. I only farm 450 acres in central Illinois. So I might consider your 6620 if I can't come up with anything. 4WD is a must though. Thanks alot!
