Hydraullic lines Model 60
RLA
07-05-2004 10:10:13
Replace rear axle seals & bearing on a 60023050 model 60. Both hydraulic must be removed from the rock shaft housing. The low side line is removed easy takes some effort on the hi side? There must be a trick to reinstall the hi side line & not ruin the new O Rings???? I have sheared 6 new R495R in half & most of the time I cannot get them even started. The Beveled hole is clean, I figure there must be a tool. The I T manual says very little about it. Never in ,my wildest dreams did I think I'd run into this? Lost & need help. I've tried every Lubricant I know of & have tried small diameter O Rings & even they shear in half.
Randy
Mike M
07-06-2004 13:02:45
 Re: Hydraullic lines Model 60 in reply to RLA, 07-05-2004 10:10:13
Bare with me as I try to refresh my memory as I have removed several of these lines in the past and never had a problem with the new seals. That being said where are you trying to put the o-ring?
I seem to remember that most of those lines have a groove in the large part on the end ,but I think that at the very end the tube sticks out and the o-ring sets on the end and can even be put into the housing first and the clamp draws it up tight.Does any of this sound possible ? It sounds like you tried every other way. Can you post a picture of the line end ?
RLA
07-07-2004 14:02:20
 Re: Re: Hydraullic lines Model 60 in reply to Mike M, 07-06-2004 13:02:45
Mike You are correct if you are replacing the lines on the 620/630 series. The O ring does go
on the end of the line. But not on the 60???
Bob
07-05-2004 10:27:05
Have you tried a TINY amount of liquid dish soap (so as not to contaminate the hydraulic system)?
That's about the slipperyest stuff to use on "O" rings.
RLA
07-06-2004 06:46:24
 Re: Re: Hydraullic lines Model 60 in reply to Bob, 07-05-2004 10:27:05
I've tried Joy dish soap & tire mounting soap? A R494R O ring is 1/8 diameter, went to a O ring assortment & tried 3/32 diameter, these appear to be closer but you will still shear them in half. & they leak a small amount of oil under pressure.
