Flywheel Help!!!!!!!!!!
Navy Chief
07-05-2004 07:41:04
I am in the middle of disassembling my beloved 1950 G Ser #44495, for restoration. I am now attempting to remove the flywheel. I got the dogleg flywheel wrench set for my Birthday last year, and it worked great for the first bolt. The problem arose when I rotated the flywheel to get at the second bolt. There appears to be recesses cast into the outer rim of the flywheel and the wrench corresponded relatively easy with the first bolt, but the second bolt has no notch on the flywheel and I am now confused as to how to loosen the second bolt to get the flywheel off. You cant get a wrench in there either! Any and all help would be greatly appreciated! R/
Eric
JDGnut
07-06-2004 11:08:37
 Re: Flywheel Help!!!!!!!!!! in reply to Navy Chief, 07-05-2004 07:41:04
Glad to hear your finally working on that G... Suprised you didn't already have the wrench.. it also fits the A's... If some install the the bolt the wrong direction is it tougher... the wrost is if some on put different bolts in the flywheel.. then the wrench will not fit.. (the flywheel bolts have oversized nuts.. ) I was looking at my flywheel for my A.. someone cut the bolts off of it with a torch.... but I still have to get the rest of the bolt out.. Good Luck..
JDGnut
Mike M
07-05-2004 17:40:10
I have done 2 G fylwheels so far with the factory wrench and haveing the bolts horizontal and the wrench sticking out by the frame I have been able to get them on and off. I use the adapter that is bent like an L in the middle and use a 3/4 drive breaker bar and socket on the end of that.
Jack kohl
07-06-2004 09:41:49
 Re: Re: Flywheel Help!!!!!!!!!! in reply to Mike M, 07-05-2004 17:40:10
I am redoing a G and my answer to getting those two bolts out was my Dewalt Recip saw with metal cutting blade. Worked like a charm. That was after making and breaking a bent extension for my 3/4 inch socket wench. Good luck.
