70 D pony still won't start
Dan
07-05-2004 04:31:59
Have done everything I can and it still will not start. I am not a complete novice as I have another 70 D that I manage to keep running. This is what I have done:
1. new plugs(autolite equivalent to J8C's)
2. new points
3. new carb gasket kit installed and every orifice cleaned.
4. set the timing and checked the spark from both coils.
5. installed coil protection switch as Cloney and FIT instructed.
6. new gas hose from tank to carb
There is one diference between this tractor and my other 70 D, this one has the 720 fuel shut off switch. It is obvious that the pony is not getting gas so I disconnected the shut off switch
from the carb and cranked the pony to check for gas. There is some, although not a pencil size flow by any means. Should I try to by pass the switch and run gas directly to the carb(unhooking that switch is not fun with all the extra plumbing)? What else should I try?
F-I-T
07-05-2004 10:35:24
 Re: 70 D pony still won't start in reply to Dan, 07-05-2004 04:31:59
third party image
Dan:
If you are getting spark and are convinced that you are not getting fuel, then that's what you have to solve. If you give it a snort of ether, will it run? If so, then you do have a fuel starvation problem.
While I'm not very familiar with the fuel shut-off plumbing of the 720 pony, I don't think that switch has anything to do with the fuel valve. I think it's just there to indicate pony oil pressure is present at the diaphragm valve. The diaphragm valve is likely stuck closed, or the diaphragm is torn (which could lead to gas in the pony oil.....not a good thing!).
If it's not leaking fuel into the carb (valve stuck open) or into the pony oil (torn diaphragm), then the valve is either not getting oil pressure (which you need to fix before you let it run) or it's getting oil pressure and not activating.
Either way, make certain you are developing adequate oil pressure, or you'll be in for an expensive repair!
Frank
Dan
07-05-2004 12:12:24
 Re: Re: 70 D pony still won't start in reply to F-I-T, 07-05-2004 10:35:24
FIT,
I have changed the diaphrams in the fuel switch and it seems to be working. I have tried using some starting fluid and found that when sprayed in to the air cleaner holes it did not fire. When I pulled the air cleaner off and sprayed down the throat of the carb then installed the air cleaner it would fire and run till it burned up the ether. The only thing I did not do to the carb was remove or mess with the float. I did remove the top cover over the float bowl and clean everything I could. When I get home from work I will try to start her again, I really do not know what else to do next.
F-I-T
07-05-2004 13:16:12
 Re: Re: Re: 70 D pony still won't start in reply to Dan, 07-05-2004 12:12:24
Dan:
Oh, I think it's not going to be too difficult to get going. You have spark, and it runs when fuel is provided, so it's just a matter of finding where the fuel flow is being impeded.
So, if it runs on ether and sounds pretty decent, then you must have a good enough spark. Also, if it keeps sparking after you let up on the starter button, and the F-I-T/Clooney circuit is working properly, then you have pony oil pressure.
It sounds like you have the hood off, which will make it easier to work on things. There is a plug in the bottom of the carb bowl. I would like to see you remove that and try the ether thing again. Or, if you have a small squirt bottle, you might be able to remove the load adjusting screw and fill the float bowl through the small hole.
While it is running you will be able to see if the fuel is getting through to the carburetor bowl. If not, you have a float/needle/seat occlusion, OR the fuel is still not getting out of the diaphragm valve. So, if you run it and fuel flows well out of the carburetor bowl, you have a carb passage(s) blocked. If no fuel appears out of the bowl, then check the line out of the diaphragm valve. If, while running, no fuel appears, it is not working or you do not have oil pressure. If fuel appears, you have a needle valve fouled or hanging up. If you get that far and the float is still the old cork type, I would replace that. Many carburetors over the years have been the victim of pieces of broken down float cork clogging the passages.
Try those tests and let's see where that leads you.
Frank
Dan
07-06-2004 04:26:38
 Re: Re: Re: Re: 70 D pony still won't start in reply to F-I-T, 07-05-2004 13:16:12
I took the carb back off and checked the float and valve and cleaned everything associated with the float. When I put it back together I filled the float bowl with fuel. It started right up and burned the fuel in the bowl, then would not restart, so I know it is not getting gas through the fuel shut off switch. After work today I am going to by pass that fuel shut off switch and see if the original manual shut off is available from John Deere. I am not surprised that shut off swich does not work very well as my other 70 D is so very sensitive to having a full gas tank and door open to run correctly.
F-I-T
07-06-2004 17:43:38
 Re: Re: Re: Re: Re: 70 D pony still won't start in reply to Dan, 07-06-2004 04:26:38
Dan:
Well, you have it figured out now. I think if you can't find the original fuel set up , you ought to just take another look at the oil pressure activated unit. There were so many used in so many applications, that you ought to be able to get it to work.
Although.....I have the good old fashioned one on my 70D and it hasn't failed me. It sure is simple to work with. I went out to the barn yesterday, and though it had sat for four weeks, it fired right up. I still like a well-tuned pony system. When they're right, they will crank anytime, any temperature.
Frank
Dan
07-06-2004 18:31:22
 Re: Re: Re: Re: Re: Re: 70 D pony still won't star in reply to F-I-T, 07-06-2004 17:43:38
Well I got the pony started this evening. I took the oil activated fuel switch off and ran gas strait to the carb. I have a manual shut off at the tank. At least I was able to still use the oil line to operate the coil protection switch. The pony runs nice although it smokes alot more than my other 70 D. This tractor has a muffler on the pony like I have seen on 830's. That makes a world of difference in the way they sound. Thanks for your help FIT.
F-I-T
07-07-2004 07:19:41
 Re: Re: Re: Re: Re: Re: Re: 70 D pony still won't in reply to Dan, 07-06-2004 18:31:22
Good deal, Dan.
If you tinker with it, you can probably get that diaphragm thing working, too, if you want, but there's is nothing wrong with the manual shut-off method. Check the oil drain holes in the heads to be sure they are not plugged. That will make them smoke as well.
Frank
