D not running properly under load or fast idle - h
JC
07-04-2004 19:00:27
Engine idles smoothly down to about 350 RPM.
As I open the throttle with no load on the engine, it runs smoothly to about 680 RPM, then it starts to "hunt" very badly. If I add a small load by driving the tractor in high gear, the engine runs very rough and the governor rapidly moves the throttle from full open to fully closed and back to fully open.
If I over-ride the governor and hold the throttle lever at a fixed position, the engine runs smoothly but the RPM drifts up and down.
What's been done:
Engine rebuilt.
Carb overhauled.
Carb passages re-checked for blockages.
Governor overhauled.
Linkage from governor to carb may not have be re-assembled to the original length.
Suggestions..... ....
Thanks,
JC
donwisc
07-04-2004 20:46:03
 Re: D not running properly under load or fast idle in reply to JC, 07-04-2004 19:00:27
Do you have a 3 way valve that would control fuel flow from the small tank or main tank. make sure it is turned all the way to the main tank. My linkage was wore enough that the valve was not fully turned and starved the carb. You can manually turn the valve instead of using the linkage.
JC
07-06-2004 15:15:29
 Re: Re: D not running properly under load or fast in reply to donwisc, 07-04-2004 20:46:03
Hi donwisc,
I have not completed the restoration. I am supplying fuel to the carb using a 1 gallon plastic fuel tank mounted about a foot above the carb. The 3-way valve isn't in the "circuit".
However, your suggestion reminds me that I should check for a continous flow of fuel out of the carb bowl drain. I only checked it for a few seconds.
TNX,
JC
