Early Styled A with missing SN plate
Geoff
07-04-2004 17:29:14
My dad bought a JD A styled with spoke rims. There is no Serial number plate on the block by the mag, but I have found two rivits in the block near the upperleft side of the block when viewing the flywheel side. SN plate is gone.
Is there any way of determing a range of serial numbers by features or casting numbers?
Any help would be much appreciated.
Thanks, Geoff
dw
07-05-2004 16:08:56
 Re: Early Styled A with missing SN plate in reply to Geoff, 07-04-2004 17:29:14
The six speed transmission was started in 1941. Prior to that, they had the four speed transmission. Shifter was enclosed in housing with six speed. Before that shifter was in open. Some of the war years had a pressure radiator cap rather than the large unpressurized cap.
dwm
07-04-2004 17:55:26
Geoff,
Yes, my brother and I have been where you are. I am assuming that with spoke wheels and a mag, this is an early styled, which would mean a straight, cast type frame, from 1939 to 1947. 1947 to 1952 have a pressed steel frame that is wide at the back over the engine, then narrows down going toward the front. While other more knowledgeable folks on this board can narrow down the serial ranges, here are some things that are different from year to year during the early styled years between 1939 and 1947. Of course this assumes what you have is original and not updated or parts taken from another tractor. Type of drawbar, straight or curved so you can turn it up or down to vary the height, a roller on the swing portion. Number of holes in the seat, generator numbers (if equipped), type of magneto. If you can get access to a parts book, it will show serial number breaks on some parts. Good luck.
