JD 720D fuel leak and starting
Bill S.
07-03-2004 11:55:24
I have a 1958 720D (SN# 7219803) that I purchased about 2 months ago. The previous owner's late father had told him to shut the fuel off at the sediment bowl when not running it because fuel would leak into the oil otherwise. The father had had someone try to fix the problem, but the son didn't know if it was fixed or not. I have been shutting the fuel off. I let the tractor set for a week on the level and it started fine. I let it set for a month on an incline with the flywheel side higher than the pulley side and the tractor would not start. I took off the tappet cover and slightly loosened the fuel lines at the injectors while the big engine was being turned over with the throttle part way open. There was fuel at the RH (pulley side) cylinder but none at the LH side. I bled the system through the LH bleed plug and it started right up. Does anyone have any ideas about where my leak might be and how to go about finding it?
Thanks for any help you can give.
Bill
