Tye, First of all, is your ammeter working properly and in BOTH charge and discharge directions??? Are you wired POSITIVE ground as original??? If you turn the lights on, does the ammeter swing to the discharge direction??? When you opened those contacts you closed, did she quit charging and did they stay open?? When you shut the tractor off, did the ammeter go to zero or swing to discharge (cutout relay sticking in)????? Sorry, but answers to these questiosn helps me in my diagnosis. ARE YOU SURE THE BATTERY IS GOOD??? (See caution note below) 1) If the ammeter works and is wired correct and you closed VR relay contacts and she charged, theres Good news n theres Bad news. Good news is the Gens probably charging, bad new is the VR may be bad or need adjusting or isnt well grounded. 2) Im unsure which VR relay (Field control or cutout portion) you activated to make her charge?? a) With the cover replaced and the tractor running, first temporarily ground the Gens Field to its case. If she charges then and when you shut the tractor off the ammeter goes to 0 and dont discharge, your VR's Field control relay is bad or needs adjusted,,,,, ,, or theres a wire missing from the VR's FLD terminal to the Gens Field post,,,,, ,,, or the VR isnt well grounded. b) If the above dont make her charge, leave the Field post grounded then jump the VR's BAT and ARM (or GEN) together and see if she charges then??? If so, your VR is bad or its cutout relay is bad or needs adjusted (to pull in and close). When you jump those VR terminals together, youre essentially closing the cutout relay contacts, so if she charges then its bad or needs adjusted. The adjustments may be the air gap distance between the contact points or the spring tension which determines at what voltage of GEN outout (higher than battery) the relay pulls in and closes. SUMMARY: Insure ammeter works in both directions,,,,, ,,,,, insure ammeter is wired correct,,,,, ,,,,, MAKE SURE VR IS WELL GROUNDED,,,,, ,,,Do the Gen Field ground (ground Fld to case) and the cutout relay by pass (BAT to ARM) tests above which will determine if the Field control or cutout relay portion of the VR is at fault. I would try to clean those relay contact points free of any carbon and then use electrical contact cleaner, but once the silver coating is gone, they dont work so well very long and may stick. If the by pass tests verify the Gen is okay and cleaning or adjusting (air gap or spring tension to make it pull in and release at correct voltages) dont cure the problem, get a new VR and be sure its compatible with your ground system. Post back your findings and any questions or e mail me at [email protected] and we will proceed. If all else is good you might take a look at the VR relay contacts and air gap and spring adjustments (be sure all grounds are good including VR). Assuming the ammeter is okay and wired proper it sounds like you simply have a bad or mis adjusted VR, regardless if its in the Field control or cutout relay portions, which the tests above will help isolate. You ought to be able to determine inside what that relay controls from where it leads to, the ARM and BAT or Field external terminals, however, it dont really matter if adjustingn dont cure it, you need a new unit anyway. CAUTION NOTE Are you sure you have a good battery????? ? cuz a bad one may not accept a charge and that manual overriding youre doing could damage something""""" """"" The Gen and VR may be okay and you are manually over controlling things to make a bad battery draw currente. YOU MAY WANT A SHOP TO LOAD TEST THE BATTERY and check your other charge system for problems before you buy a new VR or harm somethign when it never was bad in the first place maYBE???? Good Luck n God Bless, Hopefully, you simply need a new VR or an adjustment ??? Let me know John T
