H Troubles need help with carburetor
Denny Foster
07-03-2004 06:31:40
I have finally got my H together and I have troubles. I ran it last year on a small can of fuel and it ran super, now it's all together with a hood and fuel tank it is a different story. The governer constantly hunts back and forth, it is running terribly rich, popping back through the carb and you can remove the idle needle from the carb and it makes no difference in the way it runs. I have had the carb off and apart 4 times cleaned every passage I can find but evidently I am missing one somewhere??? Any help or advice would be greatly appreciated.
Denny
DaveH IA
07-04-2004 06:59:12
 Re: H Troubles need help with carburetor in reply to Denny Foster, 07-03-2004 06:31:40
The very best thing I ever done on the carb overhaul was to call Roberts Carb Service and order two drill bits to clean out the idle circit in those carbs my A and G will idle and run super getting ready to do the H next---Roberts Carb on is on line
Nor. Al
07-03-2004 19:08:09
Denny in thinking about your problem 1st it ran good on a tank that you had adapted and ran o.k. but after connecting it to regular tank it don't,If you still have the can then I would try hooking it up again and if the motor ran good then I would see if there was a restriction or varnish in the gas feed, like tank gasline and sediment bowl, you can rest assured it will be something simple that you have overlooked when you find it.
Britt
07-03-2004 10:22:15
If you haven't already tried it, try running it with the aircleaner disconnected. It could be plugged up.
Good Luck,
Britt
Denny Foster
07-03-2004 18:37:09
 Re: Re: H Troubles need help with carburetor in reply to Britt, 07-03-2004 10:22:15
I have the air cleaner off, I have cleaned it thoroughly and painted it but have not put it on yet I wanted to get this problem resolved. As far as the passages go I am sure one is plugged up but I have cleaned all I can find, a while back someone had a drawing of the passages and offered to e-mail it to another gent, but I can't remember who had it.
Thanks
Denny
Duane Larson
07-04-2004 07:36:18
 Re: Re: Re: H Troubles need help with carburetor in reply to Denny Foster, 07-03-2004 18:37:09
Denny,
The neck of the H carb has two brass plugs. Remove the top plug and behind it you will find a small hole (#54) which needs to be open. It is part of the idle circuit - it can be hard to find if plugged with rust or carbon.
Chris
07-03-2004 07:01:03
Never worked on an H but if they have the drill holes like the A's then you might try cleaning and blowing them out really good. It helped on my A.
Denny Foster
07-04-2004 14:22:31
 Re: Re: H Troubles need help with carburetor in reply to Chris, 07-03-2004 07:01:03
Thanks for the input, as far as the can vs. tank situation everything is new including the sediment bowl and fuel pours out of the line on the carb. I am certian I have a clogged passage somewhere I will check the one Duane suggested.
Thanks for the help!!!
Denny
