JD 4020D hydraullic fluid in coolant
Phil
07-02-2004 19:31:26
I hvae a 1965 JD 4020 diesel with powershift transmission. The other day I checked the fluids and the hydraulic/transmission fluid was low so I filled it up. I also checked the coolant, oil etc and everything looked fine. I was baling hay and I notice something was running down the tractor near the radiator, I was on a hillside so I didn;t give it much thought but today I checked the antifreeze and it was white and smelled like oil and then I checked the hydraulic fluid and it was low again.
How can hydraullic fluid get in the radiator, is it a dual radiator that also cools the hydraulic fluid? The hydraulic fluid looks good, it doesn't look like there is any water in it so I think there is just hyd. fluid in the radiator.
What should I look for or check.
Thanks,
Phil
richard florea
07-04-2004 19:10:46
 Re: JD 4020D hydraullic fluid in coolant in reply to Phil, 07-02-2004 19:31:26
it may be impossible but it is happening to me also. i have a john deere 2020 and i get hydrolic fluid in the radiator and water in the hydrolic fluid. i'm about ready to replace both the radiator and hydrolic cooler. i had the radiator re cored and that did not help. let me know please if anyone can solve this problem that cannot exist but does.
richard florea
09-06-2004 22:35:11
 Re: Re: JD 4020D hydraullic fluid in coolant in reply to richard florea, 07-04-2004 19:10:46
did you ever get an answer to your problem? I checked the web site but could not get in. i've read about the fancy "electrolisis cavitation" problem. sounds like a lot of overhaul work and major money. any information would be appreciated. i don't know why my responce to your problem was not posted. maybe i'm just a "dumb farmer from missouri"
bill
07-04-2004 18:30:19
are you sure it is hydraulic fluid , instead you might have oil in the radiator.And another thing you might have a hydro fluid leak somewhere else
I'm a mechanic and I never heard of a thing but there is always a first Good Luck
David from Kansas
07-04-2004 18:17:12
Phil,
65 4020 PS's must be possessed. Mine has been getting water in the transmission for several years. I used to let it set outside and thought it must be rain water getting in. I built a new hay shed, changed the transmission oil, changed the filters, and kept the tractor under the shed. A few weeks later the transmission again had water in it. Don't add any unusual amount of coolant to the tractor; maybe just a quart or two twice a year, which is probably enough to contaminate the transmission fluid. I've been told the same thing as you are being told: it's impossible because they are separate systems.
Dan
07-02-2004 21:00:09
As mentioned below Hydraulic and radiator are separate, not like car where hyd cooler is on bottom of radiator, these are 2 separate coolers and no connection. I would think perhaps the engine oil might be getting into radiator instead.
twopop
07-02-2004 20:50:10
the only way hyd fluid could get to the coolant,would be if the oil cooler had water running thru it,which it doesnt.the two are completely seperate.i cant think of any way this would happen
