51G Hyd.
Max(ia)
07-02-2004 09:18:32
Rockshaft(3pt) works fine, but can't get the JD 2 way cyl. on my brushhog to work. It has pioneer snap couplers that come out the right side of box. Have switched sides with hoses, but still doesn't work. any suggestions, thanks
Clooney
07-02-2004 11:38:26
 Re: 51G Hyd. in reply to Max(ia), 07-02-2004 09:18:32
Max, you will either need to remove the cap(s) on your remote outlet selector valve(s) [if your tractor has that {or those} in it] or swap out the rear Power-Trol plugs for closed front outlet fittings.
With it the way it is now you should have a one way remote cylinder AFTER the 3-point lifts all the way to the top of travel & no remote action the other way..
Those side ports will only work one way without closed front P/T plugs or the selector valve[(s) closed..
See if your rear P/T outlet plug(s) have a removable cap? If so, remove the cap [or caps] & close the inner valve..
Basically those old P/T systems have either rockshaft OR remote function but NOT both at the same time.
[email protected]
