Anyone know how to assemble a 4455 steering column
Matt
07-01-2004 21:26:18
I have a 4455 that had an oil leak on the bottom of the steering colum, in order to get to it i had to take the steering wheel and column completly apart, now that i got the leak fixed the column won't slide to adjust it inwards, i know there's groves it has to set in or something on the inside but not sure how it all works, could anyone help?
DON
07-02-2004 09:19:11
 Re: Anyone know how to assemble a 4455 steering co in reply to Matt, 07-01-2004 21:26:18
BEST TO HAVE YOUR DEALER PRINT YOU A COPY OF THE PARTS PAGE . NOT TOO DIFICULT WHEN YOU SEE HOW ITS PUT TOGETHER YOU SHOULD GET IT OK. BY THE WAY IF IT WAS LEAKING OUT THE TOP AROUND THE STEERING WHEEL , AT THE TOP INSIDE THE STEERING COLUMN THERE IS A NEEDLE BEARING. IT WEARS OUT AND LETS THE SHAFT COME UP OUT OF THE SEAL . I HAVE REPLACED MANY OF THESE WITH AN EXTRA WASHER TO TAKE UP THE WEAR. DON
