1938 JD A Shifter trouble
Travis Tietjen
07-01-2004 20:52:14
I have got a 38 JD A. when i make the tractor pull hard (plow)the high low lever pops into neutral any ideas what could be wrong and or how to fix it? thanks
Clooney
07-02-2004 03:22:14
 Re: 1938 JD A Shifter trouble in reply to Travis Tietjen, 07-01-2004 20:52:14
Travis, the most likely cause is worn trans bearings.. It could be as simple as the trans outer input shaft bearing worn out [that's under the small cover just behind the clutch pulley].. Worn shifter detents, or a rotating detent shaft could also be to blame.. [maybe just a shifter adjustment if you are real lucky].
~If the shifter & bearings are ok then you could have severely chipped gear teeth [or no back taper left on the gear teeth] on the input shaft to trans shaft, or a bent [or loose] shift fork..
~Lots of possibilities & about all you can do is pull the trans top cover & the small cover on the 1st reduction cover & give the trans shafts a shake by hand to look for loose bearings. Then do a visual inspection on the shifter & parts to see if you can see anything wrong..
~Most of those old A�s that I have worked on that jumped out of over/under drive have been because of worn trans bearings though..
[email protected]
