Attaching lift arm springs on a 420
Tim
07-01-2004 14:26:25
Anybody have a easy way to attach the lift arm springs on a 420? I have not tried it yet but it looks interesting. Any sage words of advise will be appreciated.
Thanks
Tim
Ray
07-01-2004 19:22:06
 Re: Attaching lift arm springs on a 420 in reply to Tim, 07-01-2004 14:26:25
Just did this today on a 420S.I used a chain hoist hooked to the spring hook with a small chain.Just stretched the spring till it fit in the hole,made an easy job.
Dave - Ia
07-01-2004 18:04:27
I have installed those springs by placing flat washers between the coils to extend the length of the spring. It takes several. You may have to separate the coils with a straight screwdriver then insert the washer to hold the coils apart.
Wayne in Tn.
07-01-2004 18:13:29
 Re: Re: Attaching lift arm springs on a 420 in reply to Dave - Ia, 07-01-2004 18:04:27
The way I do it, is to remove the bolt and remove the lift arm, then hook up the spring and reinstall the arm with spring hooked.
