430 serial number plate
Phil - MO
01-30-2004 05:01:43
I took 2 430W tractors and made one.
It turned out that the finished tractor doesn't have a serial number plate on it.
The parts tractor does.
I'm not at the farm to check it out, but it just dawned on me that maybe I should attach the plate to the finished tractor. They were both same model and style.
How is the plate attached? When I was working on it, it looked like a couple of rivets in a blind hole.
Phil
Mark
01-30-2004 10:21:33
 Re: 430 serial number plate in reply to Phil - MO, 01-30-2004 05:01:43
If you take the engine serial# to your JD dealer, I think they can get you the correct serial# and plate for your tractor. The engine# is just ahead and a little below the gen. on a flat boss on the engine casting.
Clooney
01-30-2004 05:36:01
Phil, that S/N plate is attached with rivets.. I don't know for sure on the 430 but on the 40 the rivet holes go all the way through the frame casting & can be driven out from the rear with a small pin punch..
~Those rivets are harder than Snail�s nuts so if you can�t drive them out from the rear you can grind the rivet heads of & then install new rivets in the other tractor.. I think those rivets are still available from Deere [at least they were]..
~If the rivets are broken off in the completed tractor you can drill them out with a carbide or cobalt drill bit.. OR, just drill new holes right next to the old ones & install the new plate..
[email protected]
