730 Diesel pump ???
Mike J
07-01-2004 09:28:43
My 730 D is putting fuel into oil I took cover off to look at pumps I can tell there is a leak but cant tell where. I used a mirror but it gets soaked right of way. the fuel/oil is coming out the rear of the pump on left side also filling up the timing hole. I should mention that I have two differnt pumps and inj. A couple of questions I have.
1. Do the fuel pumps get oil to them in some way (the mirror seams to have oil on it more than fuel)
2. Where is a good place to take the pumps,inj. etc. in to have them fixed. I live between Milwaukee and Green Bay Wisconsin.
3. What do you guys think it would cost to have the work done approx. cost anyways.
4. Can I do anything myself such replace o-rings or gaskets.
DON
07-02-2004 09:37:32
 Re: 730 Diesel pump ??? in reply to Mike J, 07-01-2004 09:28:43
THE PUMPS HAVE PRESSURE OIL FEEDING THEM. THE TRANSFER PUMP ON THE GOVERNER CAN LEAK FUEL INTO THE OIL AS WELL. PULL PUMPS AND INJECTORS AND HAVE THEM RUN. COST ABT $350 DEPENDING ON PARTS. CANT TELL YOU WHERE TO GO UP THERE. DON
Rousseau
07-01-2004 18:46:33
Mike I sent mine to Roy Ritter in Mo.HE did a good job on mine. It's alot cheaper than I thought.He can answer all your questions .1 816 662 4765
Good Luck Rousseau
