1020 won't keep running
Vic
07-01-2004 05:54:41
When my 1020 gas warms up it stops running. I have changed the fuel filter, coil, points, condenser, and plugs. My tractor has an "Anti-Dieseling Power Solenoid' on the carburetor. Which gets very HOT with just turning the key on and the engine isn't even running.
I did replace that part in 1997. The tractor only has 417 hours on it since this part was replaced, is it common for that to go shot that soon?? HELP
Kerry Phillips
06-04-2006 09:20:52
 Re: 1020 won't keep running in reply to Vic, 07-01-2004 05:54:41
I have the same problem you describe. Many seem to misunderstand what is happening. My tractor runs fine until it warms up. Then it shuts off and will not operate correctly until it cools down. I have always assumed that there was something heat sensitive near the ignition. I have even tried leaving the battery hood open to keep that area cooler. That seems to help a little. This is very bothersome to use a tractor that suffers from this. Did you ever get this issue resolved? If so, how?
Thanks,
Kerry Phillips
Wes
07-02-2004 21:02:01
Our 1020 is having the same trouble. Will it run without the selonoid? We are trying to get the hay in and need a quick fix for the tractor. Let me know what fixes your machine please.
Wes
John
07-01-2004 16:30:50
Ayup that solenoid has been a bit of a pain on my 1020 also. Primarily the problem is every five years or so it starts to leak fuel. I replaced the o-ring in it at least 5 times but still have the original solenoid housing in place. Cousing got tired of his too, Replaced the carb with one off an International H or something like that. Says it improved economy and performance.
David
07-01-2004 15:18:43
That part has been removed from my 1020 and 2020. Maybe it's a common problem??
