Hydraulic oil for Power Trol
GT
07-01-2004 03:10:09
What type of oil should be used for the Power Trol hydraulic system? Is regular hydraulic oil (Exxon Torque 56) OK?
Jack
07-01-2004 11:44:28
 Re: Hydraulic oil for Power Trol in reply to GT, 07-01-2004 03:10:09
Regular hydraulic oil is OK, if your system is flushed, remote cylinders are flushed and the fluid doesn't get too hot. The early hydraulic systems always specified regular engine oil (non-detergent), same grade as engine for the climate.
The problem using hydraulic fluid is its relatively low viscosity, which can create issues in older hydraulic systems. The loose tolerances generally create a propensity for piston leakage, difficulty in maintaining pressure, etc. In my "A", I've always used SAE 30 during the summer and SAE 20 during the winter, both non-detergent, with good results.
Jon C
07-01-2004 10:52:28
For the older power lifts, and I assume Power trols which have the same type gear pumps, use the same weight oil that is used in the engine.
Dan
07-01-2004 07:22:07
I think the older tractors called for engine oil(new not used) in the power trol. I have an old unstyled G and my dad always ran 40 wt oil in engine and transmission. In my 430 I use regular hydraulic oil and it seems to work fine.
Mark57-420
07-01-2004 05:56:26
What model are you talking about? My '57 420 is supposed to have SAE20 (I think), but I use 5W20, per the recommendation in the Owner's Manual. I really suggest that you get an owner's manual for whichever model of tractor you own. There is a lot of really useful information in them.
Good luck,
Mark
