Larry, that is a somewhat common problem on the early "H".. ~Start by removing the throttle rod at the carb & seeing if it will then idle down to what you need.. If so you will need to adjust the governor to carb rod [I usually set those 1 full hole short of entering the carb lever hole when both the carb & hand throttle are held wide open.. Then set the rod length between the governor arm & hand throttle shaft.. Then re-set both the idle & wide open throttle stop bolts at the steering post.. ~Next, that tractor came with a foot throttle so make sure the foot throttle spring in on correctly & not an incorrect stronger spring [or just remove the foot throttle spring].. Then make sure the flat sheetmetal strap is on the correct side of the governor arm pin & not contacting the plug wires at the magneto. ~If that engine won�t even idle down when the carb lever is held at the idle position you probably have a worn throttle plate in the carb or a vacuum leak. Try bending the throttle stop pin to allow the carb lever to move farther to the idle position. If bending that throttle stop pin doesn�t lower the idle speed [it usually does though] you might have a vacuum leak or worn valve guides.. Try running an unlit propane torch around the manifold & carb area to see if a change in idle is seen at any location. If nothing found try removing the valve cover & putting heavy oil [like gear oil] on the intake valve stems [or just moving the intake valves in their guides to see how much movement is present].. ~Other things to look at__ *Try checking the ignition timing as early timing can cause a high idle.. *Look at the carb throttle shaft bushings as worn bushings or worn throttle shaft can let excess air in.. *If the idle will come down by hand on the carb lever but not when hooked up & the linkage is adjusted correctly suspect a tossed governor internal weight.. *Gasoline in the crankcase can also cause a high idle so sniff the engine oil for signs of gasoline.. Post back any questions you have on the above�
[email protected]
