4020 Rockshaft
will
06-30-2004 10:12:54
My late 4020 rockshaft is malfunctioning (see next forum page for previous post) My question is Does the needle and washers in the added on remote cylinder outlet plate control the rockshaft operation? Thanks for your help.
will
07-02-2004 11:07:16
 Re: 4020 Rockshaft in reply to will, 06-30-2004 10:12:54
Thanks for your replies. I am going to Baker Equipment (local dealer) today to look at their manual to figure out what to do. Thanks again for your help.
david val
07-01-2004 00:14:03
yes, they do. the remotes and the plate should probably be removed and the rockshaft valves assembled and adjustrd properly.
david
Tom (Ks)
06-30-2004 17:43:43
The spring and shims set the speed the lift arms raise. The rockshaft control valve can be taken off of the rockshaft housing to be worked on. Set your load depth lever to "L" when you put the control valve back on.
Tom (Ks)
06-30-2004 17:51:45
 Re: Re: 4020 Rockshaft in reply to Tom (Ks), 06-30-2004 17:43:43
I'm sorry, place the lever in "D" not L. Then make sure you get your load lever in the right spot.
ET
06-30-2004 13:08:37
I just read your pevious post. I thinke there is a set of small bevel gears in there that need to be timed and if you pushed the lever to far you ran a gear passed the teeth. I had a 4010 apart for that reason once. Let me know what you find out. I think the valve can be taken off without removing the entire rockshaft.
