1925 D oil leaks
pat
06-30-2004 10:07:47
I have 2 questions. 1] I am having a problem with oil coming out the oil indicator rod while the tractor is running but the rod seems to fit and slide snug and 2] there is a leak at the wish bone steering rods that bolts into the front bottom crankcase. would this be seperate from the crankcase ? Any help would be great.
Mike
07-03-2004 17:37:45
 Re: 1925 D oil leaks in reply to pat, 06-30-2004 10:07:47
I have some New old stock oil ind. housings that may fit yours
Marty Z
07-01-2004 07:59:22
Pat,
Like Clooney says that stud was worn and loose on mine too. I took a big nut and sliced it in half so it was about 1/2 inch thick. I ground it to fit the inside curve of the crank case . I put it inside behind the original hole and put sealer- the real hard stuff- in the hole and on the stud. When I turned the stud in the hole I was able to catch enough thread to get it tight and let it set.
It has stayed tight and drip free for 5 yrs now.
Clooney
06-30-2004 11:21:39
Pat, I really can't help you with that indicator rod leak.. About all you can do is pull it apart & look for wear inside the housing or on the piston.
~On the crankcase to steering axle wish bone pivot bolt leak I can.. That does go into the crankcase & usually ends up being loose in the hole allowing engine oil past it.. You will have to pull it apart & use sealer on the pivot bolt stud [I usually have to make another pivot stud as the original is usually worn way undersized...
[email protected]
