1934 JD model D
Dick C
06-30-2004 07:00:31
On disassembly I found that the splines on both the vertical steering shaft and the lower pitman arm are badly worn. Someone had filled the gap with a section of aluminum drink can. Short of welding up the splines and having them re-machined, would it be feasible, and strong enough, to cut a keyway in each? I realize I would have to determine correct alignment prior to cutting the keyway.
Thanks,
Dick
CNes
06-30-2004 15:08:18
 Re: 1934 JD model D in reply to Dick C, 06-30-2004 07:00:31
With that much slack worn into the parts
I dont think a key would hold well enough
for a working tractor. But it would work well enough light use.
