3020 gasoline stalling/fuel pressure
Mark A
06-29-2004 11:58:19
I suspect a weak fuel pump. The tractor will start, and run for about 10-15 seconds and then die and not restart. When I pull off the gas line at the carb to check fuel pressure (without a guage), and then crank the engine, should I shoot gas out more than say 5-6 inches at normal cranking speed? Thanks in advance.
Huckleberry
06-29-2004 20:21:00
 Re: 3020 gasoline stalling/fuel pressure in reply to Mark A, 06-29-2004 11:58:19
Don't know what your problem is---but---once I had a similar problem...mine turned out to be a very large beetle in the fuel tank. Good luck.
Russ
06-29-2004 19:49:25
Sounds like enough fuel to me. Make sure you're not losing SPARK. Leave one plug out and see if it remains firing as the engine stalls.
KEEP US POSTED!
