A3162R Remote Cylinders
ribbitt
06-29-2004 06:35:13
I have a couple of remote hydraulic cylinders, the number cast on the side is A3162R, along with the number 80. They seem to be complete, including the correct pins and clips. Some questions....What implements would these typically be used for? What vintage tractors would have used them? Would they have been used on 30 series tractors?
One of the rods has a few pits near one end, probably from rusting and neglect. I assume this is not good for the seal in the end of the cylinder. Can these be repaired, or the rod replaced? Finally, what are these items typically worth?
John d
06-30-2004 07:36:56
 Re: A3162R Remote Cylinders in reply to ribbitt, 06-29-2004 06:35:13
A3162R is from Model A, I dont know what the 80 would be but if you wanted to send me a picture I could probably tell you. Also I can get you all the parts. I would be interested in buying them all. John
Email: [email protected]
Dan
06-29-2004 08:02:57
I believe that is a JD A cylinder. There was a B cylinder, A cylinder and G cylinder. Not sure how much that changed in the number series. I have one I have used on a mower for years. It leaked down badly and seeped a bit fro the front seal so I rebuilt it last year. I couldn't get parts from my JD dealer so I used the old cups with a piece of an old leather boot as a washer behind them. The front seal is a Chevron type and it happened that the JD dealer had one that had been sitting around a while and it fit. Does not leak or seep any more but I haven't used it a lot. I would only use it with low pressure hydraulics like the A, B, G50, 60, 70 etc. I don't remember if the 20 and 30 series had more pressure or not. I wouldn't use it with a modern system as they have too much pressure. I have seen those for sale on e bay off and on.
