2510 2520 Brakes Chatter
Paul
06-28-2004 19:01:20
I have two 2510's and two 2520's and the brakes chatter on all of them when applied. Does anyone have a definitive answer as to why this is? Some people say they are all that way, I hardly believe they were that way when new. Some say the wrong oil might of been used at one time, I have the correct oil in all of them now. Air in the lines has been mentioned; I admit to not having bleed any lines. I had the opportunty to inspect the pads and disk on one of them and they "looked" OK. I must admit I may not know what looking OK means. Is this a design flaw that shows up with use and wear? I sure would appreciate some help or direction. Thanks.
Russ
06-29-2004 19:29:39
 Re: 2510 2520 Brakes Chatter in reply to Paul, 06-28-2004 19:01:20
My dads 3010 had a chattering/locking up (touchy brake) condition when he bought it new. They soon came out with updated valves in the brake valve assembly to reduce the system pressure a little (from what he told me). That made them less touchy, but they have ALWAYS chattered. I think some of that noise may also be brake vibrations transferring through the planetaries causing them to chatter as well. I'd like a definative answer also.
Paul
06-29-2004 20:08:59
 Re: Re: 2510 2520 Brakes Chatter in reply to Russ, 06-29-2004 19:29:39
I want to thank all of you for your comments. I sure wish I could understand what is behind this chatter. While the brakes still work it is kinda irritating. Thanks all.
Larry
06-29-2004 11:04:34
I'm sorry but I don't have an answer for you, however I have a 2520 and a 3010 and the brakes work fine and make NO noise on either one.
txblu
06-29-2004 09:13:08
My 4020 did but the 4010 doesn't; think both use wet disc. The 4010 has been gone thru within the last 5 yrs, the 20 hadn't.
Mark
Glen in TX
06-29-2004 08:58:50
Every one I ever drove made some noise with brakes, 2510, 4320, 4020, 5010, 6030.... Some claim their oil will eliminate that but it never worked for us. As long as the brakes work ok and don't hop you should be fine.
