starter
russell
06-28-2004 18:29:08
I removed the starter off my 60 because it was hanging up and I was going to clean up the drive motor teeth. I thought to get the drive of I would have to take the brushes out and remove the entire assembly. I got the springs off and found out that they could have stayed on because the cone comes off seperately. Well to make this story shorter i had to take it all apart and I have put it back together now all that happens is the starter just moves a little and quits when i put power to it. I hooked it up to a battery. then I hooked it up to battery charger with it clamped to a vise bolted down to a wooden top then i put it into a drill press because i thought it was a ground problem. any ideas before i take it to someone that knows what they are doing. Thanks for the help.
Clooney
06-29-2004 03:46:55
 Re: starter in reply to russell, 06-28-2004 18:29:08
Russell,
~First, try running that starter with a set of jumper cables from a GOOD battery... Some battery chargers don't have enough current to properly operate a starter [even while on the bench]..
~If it still won�t motor correctly even with a good battery go back into it & make sure the brushes are facing the correct direction & making FULL contact with the armature commutator & that no wires or brush parts of the non grounded brush are grounding out. Make sure the wire from the contact switch isn�t grounding to the case or has poor connection.. Make sure the brush springs have good tension & are holding the brushes down good & tight..
~Make sure the armature will turn freely with NO binding & that no wires are touching the case or the armature..
~Other than that just make sure everything is back together correctly & all the wire connections are tight..
Any questions just post back or E-Mail..
[email protected]
russell
06-29-2004 05:06:22
 Re: Re: starter in reply to Clooney, 06-29-2004 03:46:55
Thanks Clooney I'll check it out.
