 ROUSSEAU, the mag spring is inside the drive cup on the X mag.. B = cup,, C = spring ~To test for a functioning spring just clamp the upper mag shaft in a Soft jawed vise, then try to turn the impulse cup (B) drive ears to the left.. If the spring is functioning you should be able to feel the spring windup.. ~While you have the mag off the tractor you should also see if the impulse stop arms (D) are working & coming out through the cup window & contacting the stop ring stop.. To do that, hold the mag upright as it is installed on the tractor with the rear of the mag [drive cup end] facing you.. Then rotate the drive cup to the left [CCW] viewed from the rear. If the little stop arm comes out & contacts the stop ring [rear ring held on with 4 screws] the arms are functioning.. There should be an arm come out every � revolution.. ~It sounds like you either have a broken impulse spring or the stop arms are bound up & rusted.. In either case the impulse cup should be removed & either the spring replaced or the arms freed up & lubricated.. If those stop arms are rusty & hang up the impulse will never operate correctly.. ~Another thing to check is that the stop ring hasn�t come loose & is turning or out of adjustment.. There should be a mark on the stop ring at both the top & bottom. On your X mag the TOP mark should be around 2 to 4 marks left of the center case mark [usually 2-1/2 to 3-1/2 marks left of center on the X mag will work fine].. ~If you have to install a new impulse spring MAKE sure you watch the direction the old one comes out as wind direction is VERY important.. Be sure to oil the new spring before installation & be VERY CAREFUL not to nick that spring or it won�t last long.. The amount of spring pre wind-up depends on the mag you have but most are ether 1 turn or 1-1/2 turns.. Give me an E-Mail if you have to install a new spring & I will send you a detailed wind-up procedure.. ~You can buy a new spring form either Deere or Roberts Carb Phone: (712)-262-5311.. ~If the mag seems to be operating correctly when removed but not when on the tractor try adding another mag to governor base gasket.. Sometimes on tractors with a worn governor or governor bearings adding a 2nd mag base gasket is all it takes to make it function correctly.. [email protected]
