Differences between JD 4010 4020
Tim G.
06-28-2004 15:35:13
Hello Friends:
As you probably can tell, I'm new to the tractor world. I don't have a need for either model, but I am entertaining the idea of buy a green tractor. I don't know why a 4020 stands out in my mind so much, other than the fact that when I see a picture of one;it's like looking at a beautiful women.
If I were to buy either a 4020 or 4010, what are some of the differences that stand out in each model? What should I steer clear of? How much should either model cost? What model years should I look for? Anything else you can think of that I should be made aware of. Thanks Fellows,
Tim
gary
06-29-2004 18:25:49
 Re: Differences between JD 4010 4020 in reply to Tim G., 06-28-2004 15:35:13
Man do I have a just what you need, look on ebay item # 3824217061
buickanddeere
06-29-2004 13:50:38
You can even go for a 4320,4620,5020 or a 6030 for about the same money. Something to consider.
T213R
06-29-2004 11:00:03
A few quick differences:
1.) Engines in the 4020 are bigger, although by now just about all 4010s have had a set of bigger 4020 sleeves and pistons put in them at overhaul and produce 4020 hp levels.
2.) Hydraulic couplers are different.
3.) The 4010 has a 3rd reverse gear on the 4/7 quadrant that the 4020 does not have.
4.) The 4020 is a bit heavier than the 4010.
5.) The 4020 can have a powershift transmission
5.) The controls were rearranged a bit.
6.) The 4020 can have a power differential lock.
7.) The 4020 is newer and costs more (generally speaking)!
txblu
06-29-2004 09:18:34
Had a 4020 LP bought for $5k
Have a 4010D bought for $4.5k
Painted and rubbered both.
Did an inframe on the 4020 engine
Nothing on the 4010 as it had been done
Diesel is the only way to go for many reasons
HP is about 15 more for the 20 but that is a variable depending on a ton of things.
Since one was gas and the other diesel, can't compare performance. The two I had seemed to operate about the same; functionally, and tugging performance.
Mark
search
06-28-2004 20:09:19
do a search ,its been done sveral x's
