'49 A main bearing question
Nick
06-28-2004 13:22:51
The main bearings on this tractor have alot of play. Do the shims that are in these come in different thicknesses? If so, where can I get them besides deere? they list them at $47 dollars apeice. Thanks, Nick
F-I-T
06-28-2004 14:14:51
 Re: '49 A main bearing question in reply to Nick, 06-28-2004 13:22:51
Nick:
Though it's been a while for me, I seem to remember that that is a set of shims, or a stack glued together with a wipe of solder on the edge. You just peel off what you don't need. There are several different thicknesses stacked together so you can remove just what you need, check them with a mike if you have one, and install. You can also cut your own shims if you have some brass or steel sheet, and a good tin snips, and a good sharp gasket cutter.
We used to make them out of tobacco cans, and such, and finsh off with some know sized feeler gage stock.
Frank
