1957 JD720Gas
Bigcat
06-28-2004 12:50:07
Just purchased a JD 720 Gas #7215231 a few months back for family hay rides and brush hog work ext. Last year while pulling a group around my property with my Super C the hay ride turned into a sleigh ride down a small hill....scarry but everyone ended safe so I deceided to beef up.
The Tractor is in AAA shape,completely redone great paint, new tires, electronic ignition ect..... and runs great but consumes gas. Would rebuilding the carb help or is this just the way she runs? What do you think it's worth? Is it a tractor to keep..... .new John Deere owner?
Clooney
06-29-2004 04:09:11
 Re: 1957 JD720Gas in reply to Bigcat, 06-28-2004 12:50:07
Bigcat, actually the 720G isn't that bad on fuel compared to something like the 70G.. That tractor is a work tractor & if you just play with it, it will seem to use a lot of fuel. Under load it will do a lot of work for the fuel used.. Just playing, it will use plenty even at low RPM�s..
~You might be able to increase the economy by adjusting the load needle on the bottom center of the carb.. There is an adjustable load metering screw in the center of the bowl nut. Try turning that screw in as far as you can & still live with the engine operation. The more you turn that screw in the worse the tractor will want to take the throttle but the better the fuel economy will be.. That screw is just a by-pass screw so it can be turned all the way in & not hurt the engine but if turned in too far the engine will sag, stumble & run rather poorly.
~Another place to look is at the air cleaner.. That oil cup must be clean & have rather thin oil in it [I use 10W in most of mine unless worked hard in dusty conditions] .. If the intake snorkel is plugged with oily residue & dirt or mud dauber nests it will just suck the fuel.. There is an upper element that also tends to plug with dirt & to clean that the entire air cleaner has to be removed & taken apart..
~Another thing to try is playing with the engine timing.. Sometimes a little more ignition advance will pick the fuel economy up rather significantly. Be careful to not advance it too far, if then engine kicks back during cranking it can break the starter�s nose cone..
[email protected]
buickanddeere
06-28-2004 19:08:58
For a gasser they were still fairly efficent. Not the 1st choice for heavy continious workhowever. Fine for an odd jobs or loader tractor that is start/stopped every few minutes. When loaded to thier last gasp they made 11.12 HP per hour on a gallon of gasoline. Not too bad unless compaired to the diesel 720/730 which set a record which stood until 1984 if memory serves. Made 17.97 HP per hr per gallon. The gassers if operated at the recomended load of 80% of maximum had somewhat better numbers which were quoted from Deere in Two Cylinder Magazine a few years back. Can't find the article now but it seems like 14 HP/gallon per hour or so.
Mike M
06-28-2004 12:56:21
Lots of cubic inches takes a lot of gas to go.
bigcat
06-28-2004 13:02:12
 Re: Re: 1957 JD720Gas in reply to Mike M, 06-28-2004 12:56:21
Ya,but to farm in 1957 you would have to buy 2 tractors 1 to plow and 1 to pull the gas tanker truck at this rate.
Mike M
06-28-2004 13:11:32
 Re: Re: Re: 1957 JD720Gas in reply to bigcat, 06-28-2004 13:02:12
Thats why you hardly see 720 gas tractors as most were diesel they would pay for thierselves with the fuel money they saved.
steveormary
06-28-2004 14:35:29
 Re: Re: Re: Re: 1957 JD720Gas in reply to Mike M, 06-28-2004 13:11:32
Bigcat;
If the big problem is fuel consumption and depending on what you want to do with it,go ahead and keep it.
steve
