Window replacement
as
06-28-2004 11:23:58
I have a 4020 with a JD cab. I was mowing this weekend. THe mower kicked up a rock and shattered the rear window. My JD dealer says they no longer carry replacement windows. I want to take out the window frame and take it to a glass shop to be fitted. My question is how do I get the frame off, or is it even possible to take it off. It appears to be on a piano type hinge. Is it possilbe to take the pins out or is it peened or pressed in there? I want to avoid their hefty service call if at all possilbe.
Thanks for any help.
Ralph
06-28-2004 16:13:57
 Re: Window replacement in reply to as, 06-28-2004 11:23:58
Ours has a simple hinge, (pin is fastened to one member). Window was lifted to provide clearance and then moved out with a rubber mallet. Assembly was taken to our local glass shop for replacement with saftey glass.
