I have a 1962 or 1963 JD 2010 row crop utility. The three point hitch will lift me fine all the way from bottom to top. It does not drift down at all. If I put my 6' bush hog on it will not lift it. You can see it start but gets to so much weight and just stops lifting. If I raise the bush hog with a jack and set the height where it is the tractor will carry the weight of the bush hog off the ground.A friend of a friend of a - well you get the idea - said if you pressurize the transmission through the vent behind the seat it will help to "re-prime" the rockshaft hydraulics. We tried that with no luck, up to around 50-60 lbs, I would guess. Hope we didn't blow any seals. Anyone heard of doing this? Second question - I have remote hydraulics controlled from the dash. The valve is leaking and I do not have a use for the remotes. It looks like the valve is fed through a casting that bolts to the top of the transmission housing under the dash, just behind where it bolts to the motor. Can I take this off and put a plate over the hole, or does JD make a plate to remove the remote valve that will cover the supply pipe? I currenty have the three point hitch chained up to the rockshaft housing to keep the cutting height right for my bush hog and if I get "hooked" on something out in the field it will be a bit of a chore to get it off if I cannot raise the cutter. Thanks in advance for any and all help with this. Dave / Believer45
