Help identifying JD B
Nate JD
06-27-2004 20:23:58
I bought a B and I can't read the serial number plate. I was told it was a 41. At the Expo this weekend I saw what was claimed to be a 41 and it had the angle iron front end support (frame). Mine has the cast front end support, 1 1/8" PTO, black outlined decals, seperate gas and fuel tanks. I had a 44 B that had the cast front end support too. Guess my question is when did the cast frame start and stop? Thanks.
Nate
Stan - Florida
06-29-2004 08:47:53
 Re: Help identifying JD B in reply to Nate JD, 06-27-2004 20:23:58
Since you haven't had any other responses, I'll take a stab at it. I'm sure no expert, but from what I've read on here, the cast iron front end support was a wartime (WW II, the "big" war) thing, and I think they were built that way in 1943 and '44.
The black outlined decals were first used on 1941 models, I believe (Travis Jorde told me that when I bought mine for my '41 B).
Perhaps someone more knowledgable than me will see your post and give you more help.
Stan Huff
Melbourne, FL
Nate JD
06-29-2004 09:10:02
 Re: Re: Help identifying JD B in reply to Stan - Florida, 06-29-2004 08:47:53
Stan,
Thanks for your reply. I did a little more digging and found cast frames were used 42-44. The small PTO ended in 43, so I have a 42 or 43 I guess.
Nate
Stan - Florida
06-29-2004 09:56:14
 Re: Re: Re: Help identifying JD B in reply to Nate JD, 06-29-2004 09:10:02
Glad you got it figured out a little further. Good luck with the project.
Stan
