49' A OIL CANISTER
Butch ( PA )
06-27-2004 16:03:57
I took off the oil canister to take out the oil filter, put it back on and did not tighten up too much, now I can't get it back off. The bolt turns both ways and will not come off. Any suggestions.
Clooney
06-28-2004 04:03:20
 Re: 49' A OIL CANISTER in reply to Butch ( PA ), 06-27-2004 16:03:57
Butch, that isn't good news!!
~When the oil filter lower cover bolt spins free that usually means a damaged or broken oil filter cover/head up in the crankcase as that is what that stud threads into..
~You will probably have to drain the engine oil, then pull the crankcase cover & see if you can find a problem on top of the filter can inside the bottom of the crankcase. You will find it is hard to see down in there & even harder to work..
~It might not hurt to drill a hole up through the lower cap nut & make sure the stud is actually spinning & not that the nut is just spinning on the stud due to stripped threads..
[email protected]
