Help, Putt-Putt is giving fits!
TP from Central
06-27-2004 11:51:39
The last couple of weeks the old "A" wasn't running right..... ....So my brother ordered a carb kit and got new cap, rotor, points/condenser, for the mag along with plugs and wires. We put them in and now it runs like it is laboring at an idle and drops the #2 cylinder some times.
Anyone have any ideas on what the problem could be?
Mike M
06-28-2004 10:11:26
 Re: Help, Putt-Putt is giving fits! in reply to TP from Central PA, 06-27-2004 11:51:39
You say it drops #2 sometimes at idle ? Those older models with single induction carb. do drop #2 at idle due to the way the fuel is feed into that cylinder. Put it on a load and see how it runs.A belt or pto load is best as you can adjust the carb. at load. If you still have a miss try different plugs as sometimes new ones are bad.
Village Blacksmith
06-27-2004 21:30:02
The first two things I would look for would be:
1. Be sure the points are adjusted to .015
2. Adjust the idle needle on the carburetor
3. Verify that the start timing is correct
TP from Central PA
06-28-2004 08:02:39
 Re: Re: Help, Putt-Putt is giving fits! in reply to Village Blacksmith, 06-27-2004 21:30:02
Yeah, did all that already and it checks out.
Something tells me that I need to adjust the valves..... ..... .Might try that. Never know what could be wrong in there.
