Hello david val 2120 PTO
txblu
06-27-2004 07:33:17
Got your last answer. Thanks
This guy is transmission driven, 540 only. It is one of the 3 combinations shown in the book.
I am sure a spline is sheared as rotation produces the thunk thunk thunk as you slowly rotate the PTO shaft from outside.
I want to understand what can be done from the rear "quill" opening once the shaft has been removed and what might be the weakest link to shear with a PTO overload.
Thanks,
Mark
david val
06-28-2004 01:34:03
 Re: Hello david val 2120 PTO in reply to txblu, 06-27-2004 07:33:17
from the rear you can only remove the rear pto shaft which is about 30 inches long. you remove the 3 1/2 inch bolts and remove the shaft together with the quill. with the shaft removed you can check the splines on the shaft and with good lighting, the inner splines of the shift collar (btw, these shafts sometimes brake), also you can now check operation of shift mechnism (shift collar should move about 1 inch between engaged and disengaged positions).
the pto is engine driven and not transmission driven. the probable points of the problem you talk about are bad shifting, bad pto clutch and broken pto shaft.
david
