JD 205 Rotory Cutter
Bob
06-27-2004 06:31:18
Bought the JD 205 mower yesterday and need some help. The top link has been modified. I need to "un-modifiy" and was hoping someone might have a pic of what this should look like, or describe what it should be.
There are two pieces of steel that come up from the front that are bent at the top to form the location for the tractor's top link to fit into. These two are not connected at all. It seems that there should be a bushing or something to join the two together, while still leaving the opening for the top link.
There are also two steel bars coming from the back of the mower, and bent about 45 degrees to come close to meeting the top link.
My question is how do they all join together?
Thanks
Pat O.
06-27-2004 07:20:27
 Re: JD 205 Rotory Cutter in reply to Bob, 06-27-2004 06:31:18
I don't have your particular model, but have worked on a few different mower decks. The ones I've worked on just have a space for the top link to fit into, no bushings or spacers... As for the legs from the back to the front, as long as they are attached to the front structure, the mower deck should work fine. Hope this helps!
